Skip to content
GitLab
Projects
Groups
Snippets
Help
Loading...
Help
Help
Support
Community forum
Keyboard shortcuts
Submit feedback
Contribute to GitLab
Sign in
Toggle navigation
E
elp
Project overview
Project overview
Details
Activity
Releases
Repository
Repository
Files
Commits
Branches
Tags
Contributors
Graph
Compare
Issues
0
Issues
0
List
Boards
Labels
Service Desk
Milestones
Merge Requests
0
Merge Requests
0
CI / CD
CI / CD
Pipelines
Jobs
Schedules
Operations
Operations
Incidents
Environments
Packages & Registries
Package Registry
Analytics
Analytics
CI / CD
Repository
Value Stream
Wiki
Wiki
Snippets
Snippets
Members
Members
Collapse sidebar
Close sidebar
Activity
Graph
Create a new issue
Jobs
Commits
Issue Boards
Open sidebar
崔为之
elp
Commits
4b6bdfaa
Commit
4b6bdfaa
authored
Nov 04, 2023
by
崔为之
Browse files
Options
Browse Files
Download
Email Patches
Plain Diff
parent
53d881b0
Changes
Show whitespace changes
Inline
Side-by-side
Showing
1 changed file
with
15 additions
and
0 deletions
+15
-0
application/libs/config/local.py
+15
-0
No files found.
View file @
4b6bdfaa
@@ -18,12 +18,27 @@ import yaml
class
LocalConfig
class
LocalConfig
def
__init__
self
config_dir
str
def
__init__
self
config_dir
str
Initialize a LocalConfig instance.
:param config_dir: The directory where the config files are located.
self
config_dir
config_dir
self
config_dir
config_dir
def
load
self
filename
str
Any
def
load
self
filename
str
Any
Load a config file and return its content.
:param filename: The name of the config file to load.
:return: The content of the config file.
:raises FileNotFoundError: If the file does not exist.
# Construct the full path of the config file
filepath
os
path
join
self
config_dir
filename
filepath
os
path
join
self
config_dir
filename
# Check if the file exists
if
not
os
path
exists
filepath
if
not
os
path
exists
filepath
raise
FileNotFoundError
f
'No such file or directory:
filepath
raise
FileNotFoundError
f
filepath
# Open the file and load its content
with
open
filepath
'r'
as
file
with
open
filepath
'r'
as
file
cfg
yaml
safe_load
file
cfg
yaml
safe_load
file
cfg
cfg
Write
Preview
Markdown
is supported
0%
Try again
or
attach a new file
Attach a file
Cancel
You are about to add
0
people
to the discussion. Proceed with caution.
Cancel
Please
register
or
sign in
to comment
