Skip to content
GitLab
Projects
Groups
Snippets
Help
Loading...
Help
Help
Support
Community forum
Keyboard shortcuts
Submit feedback
Contribute to GitLab
Sign in
Toggle navigation
E
elp
Project overview
Project overview
Details
Activity
Releases
Repository
Repository
Files
Commits
Branches
Tags
Contributors
Graph
Compare
Issues
0
Issues
0
List
Boards
Labels
Service Desk
Milestones
Merge Requests
0
Merge Requests
0
CI / CD
CI / CD
Pipelines
Jobs
Schedules
Operations
Operations
Incidents
Environments
Packages & Registries
Package Registry
Analytics
Analytics
CI / CD
Repository
Value Stream
Wiki
Wiki
Snippets
Snippets
Members
Members
Collapse sidebar
Close sidebar
Activity
Graph
Create a new issue
Jobs
Commits
Issue Boards
Open sidebar
崔为之
elp
Commits
53d881b0
Commit
53d881b0
authored
Nov 04, 2023
by
崔为之
Browse files
Options
Browse Files
Download
Email Patches
Plain Diff
parent
7298d3cb
Changes
Show whitespace changes
Inline
Side-by-side
Showing
1 changed file
with
19 additions
and
0 deletions
+19
-0
application/libs/config/consul.py
+19
-0
No files found.
View file @
53d881b0
@@ -18,12 +18,31 @@ import yaml
class
ConsulConfig
class
ConsulConfig
def
__init__
self
host
'localhost'
port
8500
token
None
dc
'dc1'
def
__init__
self
host
'localhost'
port
8500
token
None
dc
'dc1'
Initialize a ConsulConfig instance.
:param host: The host of the Consul server. Default is 'localhost'.
:param port: The port of the Consul server. Default is 8500.
:param token: The Consul token. Default is None.
:param dc: The datacenter to use. Default is 'dc1'.
self
token
token
self
token
token
self
dc
dc
self
dc
dc
# Create a Consul client instance
self
client
consul
Consul
host
host
port
port
token
token
dc
dc
self
client
consul
Consul
host
host
port
port
token
token
dc
dc
def
get
self
key
str
Any
def
get
self
key
str
Any
Retrieve the value of a key from the Consul KV store.
:param key: The key to retrieve.
:return: The value of the key.
:raises KeyError: If the key is not found in Consul.
# Retrieve the key-value pair from Consul
_
data
self
client
kv
get
key
key
token
self
token
dc
self
dc
_
data
self
client
kv
get
key
key
token
self
token
dc
self
dc
# If the key-value pair is not found, raise an exception
if
data
is
None
if
data
is
None
raise
KeyError
f
'Key
key
not found in Consul.'
raise
KeyError
f
'Key
key
# Load the value from the key-value pair as YAML
yaml
load
data
'Value'
Loader
yaml
FullLoader
yaml
load
data
'Value'
Loader
yaml
FullLoader
Write
Preview
Markdown
is supported
0%
Try again
or
attach a new file
Attach a file
Cancel
You are about to add
0
people
to the discussion. Proceed with caution.
Cancel
Please
register
or
sign in
to comment
