Skip to content
GitLab
Projects
Groups
Snippets
Help
Loading...
Help
Help
Support
Community forum
Keyboard shortcuts
Submit feedback
Contribute to GitLab
Sign in
Toggle navigation
E
elp
Project overview
Project overview
Details
Activity
Releases
Repository
Repository
Files
Commits
Branches
Tags
Contributors
Graph
Compare
Issues
0
Issues
0
List
Boards
Labels
Service Desk
Milestones
Merge Requests
0
Merge Requests
0
CI / CD
CI / CD
Pipelines
Jobs
Schedules
Operations
Operations
Incidents
Environments
Packages & Registries
Package Registry
Analytics
Analytics
CI / CD
Repository
Value Stream
Wiki
Wiki
Snippets
Snippets
Members
Members
Collapse sidebar
Close sidebar
Activity
Graph
Create a new issue
Jobs
Commits
Issue Boards
Open sidebar
崔为之
elp
Commits
fe0e6f82
Commit
fe0e6f82
authored
Nov 04, 2023
by
崔为之
Browse files
Options
Browse Files
Download
Email Patches
Plain Diff
parent
41394999
Changes
Show whitespace changes
Inline
Side-by-side
Showing
2 changed files
with
41 additions
and
5 deletions
+41
-5
application/config/config.yaml
+3
-0
application/libs/flask_loguru/logger.py
+38
-5
No files found.
View file @
fe0e6f82
@@ -20,3 +20,6 @@ Elasticsearch:
CaCerts
CaCerts
Index
filebeat-ctocst_router-2021.11
Index
Type
_doc
Type
_doc
Logger
Level
DEBUG
View file @
fe0e6f82
@@ -10,35 +10,60 @@
@@ -10,35 +10,60 @@
# @Description :
# @Description :
import
os
import
sys
import
sys
from
flask
import
Flask
request
g
from
flask
import
Flask
request
g
from
loguru
import
logger
from
loguru
import
logger
from
.format
import
patching
from
.format
import
patching
from
application.common
import
ConfigHelper
class
FlaskLoguru
class
FlaskLoguru
def
__init__
self
app
None
def
__init__
self
app
None
Initialize the FlaskLoguru instance.
If an app is provided, also initialize that app for logging.
if
app
is
not
None
if
app
is
not
None
self
init_app
app
self
init_app
app
def
init_app
self
app
Flask
None
def
init_app
self
app
Flask
None
"""Initialize the app"""
Initialize the given app for logging with Loguru.
This involves setting up a new logger and registering it with the app.
# Remove any existing handlers from the logger
logger
remove
logger
remove
# 获取日志级别
level
app
config
Logger
Level
if
app
config
get
'Logger'
is
not
None
else
'DEBUG'
config_helper
ConfigHelper
app
# Fetch the logging configuration from the app's config
cfg
config_helper
Logger
# Get the log level from the config, or default to 'DEBUG' if not provided
level
cfg
Level
or
'DEBUG'
# Add a new handler to the logger with the configured log level
logger
add
sys
stderr
level
level
format
patching
logger
add
sys
stderr
level
level
format
patching
# 注册扩展
# Register this logger with the app
# If the app does not already have an 'extensions' attribute, add one
if
not
hasattr
app
'extensions'
if
not
hasattr
app
'extensions'
app
extensions
app
extensions
# Initialize the app's 'loguru' extension if it does not already exist
app
extensions
setdefault
'loguru'
app
extensions
setdefault
'loguru'
# Register this logger with the app's 'loguru' extension
app
extensions
'loguru'
self
logger
app
extensions
'loguru'
self
logger
app
before_request
app
before_request
def
before_request
def
before_request
A function to run before each request.
Logs the start of the request.
data
dict
data
dict
url
request
url
url
request
url
method
request
method
method
request
method
@@ -50,11 +75,19 @@ class FlaskLoguru:
app
after_request
app
after_request
def
after_request
response
def
after_request
response
A function to run after each request.
Logs the completion of the request.
g
logger
info
'Request completed'
g
logger
info
'Request completed'
response
response
app
teardown_request
app
teardown_request
def
teardown_request
exception
None
def
teardown_request
exception
None
A function to run when ending each request,
either because the request was completed or because an error occurred.
if
exception
if
exception
data
dict
data
dict
exception
str
exception
exception
str
exception
Write
Preview
Markdown
is supported
0%
Try again
or
attach a new file
Attach a file
Cancel
You are about to add
0
people
to the discussion. Proceed with caution.
Cancel
Please
register
or
sign in
to comment
