Commit 6f2970c9 authored by 赵文静's avatar 赵文静
修改dockerfile
parent 3deffa3f
FROM golang:1.18 AS builder FROM golang:1.18 AS builder
WORKDIR /usr/src/tencent-nlu-parse WORKDIR /usr/src/speech_nlu_parse
COPY ./go.mod /usr/src/tencent-nlu-parse/ COPY ./go.mod /usr/src/speech_nlu_parse/
COPY ./go.sum /usr/src/tencent-nlu-parse/ COPY ./go.sum /usr/src/speech_nlu_parse/
ENV GOPROXY=http://10.7.83.190:6666,https://proxy.golang.com.cn,direct CGO_ENABLED=0 ENV GOPROXY=http://10.7.83.190:6666,https://proxy.golang.com.cn,direct CGO_ENABLED=0
...@@ -12,9 +12,9 @@ RUN echo "hosts: files dns" > /etc/nsswitch.conf && \ ...@@ -12,9 +12,9 @@ RUN echo "hosts: files dns" > /etc/nsswitch.conf && \
echo -e "112.19.0.219 goproxy.cn\n157.255.30.117 mirrors.aliyun.com">>/etc/hosts && \ echo -e "112.19.0.219 goproxy.cn\n157.255.30.117 mirrors.aliyun.com">>/etc/hosts && \
go mod download go mod download
COPY . /usr/src/tencent-nlu-parse/ COPY . /usr/src/speech_nlu_parse/
RUN go build -o tencent-nlu-parse RUN go build -o speech_nlu_parse
FROM alpine as runner FROM alpine as runner
...@@ -22,11 +22,11 @@ COPY --from=builder /usr/share/zoneinfo/Asia/Shanghai /etc/localtime ...@@ -22,11 +22,11 @@ COPY --from=builder /usr/share/zoneinfo/Asia/Shanghai /etc/localtime
COPY --from=builder /etc/ssl/certs/ca-certificates.crt /etc/ssl/certs/ COPY --from=builder /etc/ssl/certs/ca-certificates.crt /etc/ssl/certs/
COPY --from=builder /usr/src/tencent-nlu-parse/tencent-nlu-parse /tmp/ COPY --from=builder /usr/src/speech_nlu_parse/speech_nlu_parse /tmp/
RUN echo -e "10.7.82.56 e-con-01\n10.7.83.97 m-nlp-03\n10.7.82.133 s-ipd-01\n10.7.80.153 c-gtw-01\n10.7.83.174 s-gtw-01">>/etc/hosts && \ RUN echo -e "10.7.82.56 e-con-01\n10.7.83.97 m-nlp-03\n10.7.82.133 s-ipd-01\n10.7.80.153 c-gtw-01\n10.7.83.174 s-gtw-01">>/etc/hosts && \
ls /tmp/tencent-nlu-parse && \ ls /tmp/speech_nlu_parse && \
chmod +x /tmp/tencent-nlu-parse chmod +x /tmp/speech_nlu_parse
CMD ["/tmp/tencent-nlu-parse","-config=env/v2,tencent_nlu_parse/conf","-consul=http://e-con-01:8500", "-name=tencent_nlu_parse","-token=c89cb8e1-dc45-b8d2-1b06-c02684e09b21"] CMD ["/tmp/speech_nlu_parse","-config=env/v2,speech_nlu_parse/conf","-consul=http://e-con-01:8500", "-name=speech_nlu_parse","-token=c89cb8e1-dc45-b8d2-1b06-c02684e09b21"]
...@@ -12,9 +12,9 @@ pipeline{ ...@@ -12,9 +12,9 @@ pipeline{
registryDomain = ".gree.com" registryDomain = ".gree.com"
repo = "docker_proxy" repo = "docker_proxy"
port = 17971 port = 17971
jobName ="tencent-nlu-parse" jobName ="speech_nlu_parse"
node="s-otr-01" node="s-otr-01"
index="fluentd-tencent_nlu_parse" index="fluentd-speech_nlu_parse"
triggers{ triggers{
GenericTrigger( GenericTrigger(
...@@ -22,7 +22,7 @@ pipeline{ ...@@ -22,7 +22,7 @@ pipeline{
[key: 'ref', value: '$.ref'] [key: 'ref', value: '$.ref']
causeString: 'Triggered on $ref', causeString: 'Triggered on $ref',
token: 'tencent-nlu-parse-b73b246d4bc9c5c9', token: 'speech_nlu_parse-b73b246d4bc9c5c9',
printContributedVariables: true, printContributedVariables: true,
printPostContent: true, printPostContent: true,
silentResponse: false, silentResponse: false,
...@@ -48,7 +48,7 @@ pipeline{ ...@@ -48,7 +48,7 @@ pipeline{
userRemoteConfigs: [[ userRemoteConfigs: [[
credentialsId: 'b56f8c12-cad2-41f0-a85f-36b3b3dc3241', credentialsId: 'b56f8c12-cad2-41f0-a85f-36b3b3dc3241',
// credentialsId: '4ec77ef2-5f46-4b8a-b55c-f047f6fdae7d', // credentialsId: '4ec77ef2-5f46-4b8a-b55c-f047f6fdae7d',
url: 'https://api.gree.com/gitlab/560310/tencent-nlu-parse.git' url: 'https://api.gree.com/gitlab/zwj/speech_nlu_parse.git'
echo "Building shortCommit $tagName" echo "Building shortCommit $tagName"
