Commit ce1c23a9 authored by 赵文静's avatar 赵文静
修改为端口复用
parent ee471383
Pipeline #5411 passed with stage
in 0 seconds
# 更新日志
## [0.0.1-beta.3] - 2025.6.6-6.11
## [0.0.1-beta.3] - 2025.6.6-6.14
### Changed
- 更改为redis存储sessionId
- 修复查询历史上的今天切片越界问题
......@@ -8,6 +8,7 @@
- 修改新闻title
- 修改sessionId记录
- 修改播控
- 增加一个http的入口
## [0.0.1-beta.2] - 2025.5.29
### Changed
POST http://localhost:19990/semantic/unisoundc2c/speech-nlu-parse
POST http://localhost:13302/semantic/unisoundc2c/speech-nlu-parse
Content-Type: application/json
"ip": "14.215.222.17",
"mac": "ece154a865eb",
"mid": "11011",
"query":"今天星期几",
"query":"明天天气",
"requestId": "123456111"
......@@ -45,7 +45,7 @@ Content-Type: application/json
"nluRet": {
"asr_recongize": "",
"text": "今天星期几"
"text": "珠海在哪里"
"version": "v0"
......@@ -7,7 +7,6 @@ Server:
ConsulAddr: 172.28.124.105:8500 #consul的地址
Interval: 10 #健康检查间隔,单位:秒
Deregister: 1 #注销时间,相当于过期时间,单位:分钟
HttpPort: 19990
UriPath: /semantic/unisoundc2c/speech-nlu-parse
RabbitMq:
......@@ -60,6 +60,7 @@ require (
github.com/pelletier/go-toml/v2 v2.2.2 // indirect
github.com/pkg/errors v0.9.1 // indirect
github.com/smartystreets/goconvey v1.8.0 // indirect
github.com/soheilhy/cmux v0.1.5 // indirect
github.com/spf13/afero v1.9.5 // indirect
github.com/spf13/cast v1.5.1 // indirect
github.com/spf13/jwalterweatherman v1.1.0 // indirect
......@@ -360,6 +360,8 @@ github.com/sirupsen/logrus v1.4.2/go.mod h1:tLMulIdttU9McNUspp0xgXVQah82FyeX6Mwd
github.com/smartystreets/assertions v1.13.1 h1:Ef7KhSmjZcK6AVf9YbJdvPYG9avaF0ZxudX+ThRdWfU=
github.com/smartystreets/goconvey v1.8.0 h1:Oi49ha/2MURE0WexF052Z0m+BNSGirfjg5RL+JXWq3w=
github.com/smartystreets/goconvey v1.8.0/go.mod h1:EdX8jtrTIj26jmjCOVNMVSIYAtgexqXKHOXW2Dx9JLg=
github.com/soheilhy/cmux v0.1.5 h1:jjzc5WVemNEDTLwv9tlmemhC73tI08BNOIGwBOo10Js=
github.com/soheilhy/cmux v0.1.5/go.mod h1:T7TcVDs9LWfQgPlPsdngu6I6QIoyIFZDDC6sNE1GqG0=
github.com/spf13/afero v1.9.5 h1:stMpOSZFs//0Lv29HduCmli3GUfpFoF3Y1Q/aXj/wVM=
github.com/spf13/afero v1.9.5/go.mod h1:UBogFpq8E9Hx+xc5CNTTEpTnuHVmXDwZcZcE1eb/UhQ=
github.com/spf13/cast v1.5.1 h1:R+kOtfhWQE6TVQzY+4D7wJLBgkdVasCEFxSUBYBYIlA=
......@@ -502,6 +504,7 @@ golang.org/x/net v0.0.0-20200707034311-ab3426394381/go.mod h1:/O7V0waA8r7cgGh81R
golang.org/x/net v0.0.0-20200822124328-c89045814202/go.mod h1:/O7V0waA8r7cgGh81Ro3o1hOxt32SMVPicZroKQ2sZA=
golang.org/x/net v0.0.0-20201021035429-f5854403a974/go.mod h1:sp8m0HH+o8qH0wwXwYZr8TS3Oi6o0r6Gce1SSxlDquU=
golang.org/x/net v0.0.0-20201031054903-ff519b6c9102/go.mod h1:sp8m0HH+o8qH0wwXwYZr8TS3Oi6o0r6Gce1SSxlDquU=
golang.org/x/net v0.0.0-20201202161906-c7110b5ffcbb/go.mod h1:sp8m0HH+o8qH0wwXwYZr8TS3Oi6o0r6Gce1SSxlDquU=
golang.org/x/net v0.0.0-20201209123823-ac852fbbde11/go.mod h1:m0MpNAwzfU5UDzcl9v0D8zg8gWTRqZa9RBIspLL5mdg=
golang.org/x/net v0.0.0-20201224014010-6772e930b67b/go.mod h1:m0MpNAwzfU5UDzcl9v0D8zg8gWTRqZa9RBIspLL5mdg=
golang.org/x/net v0.0.0-20210226172049-e18ecbb05110/go.mod h1:m0MpNAwzfU5UDzcl9v0D8zg8gWTRqZa9RBIspLL5mdg=
......@@ -7,6 +7,7 @@ import (
"fmt"
"github.com/gin-gonic/gin"
grpc_middleware "github.com/grpc-ecosystem/go-grpc-middleware"
"github.com/soheilhy/cmux"
"google.golang.org/grpc"
"google.golang.org/grpc/health/grpc_health_v1"
"google.golang.org/grpc/reflection"
......@@ -114,13 +115,23 @@ func main() {
database.InitRedis()
// 初始化 gRPC
// 创建监听
lis, err := net.Listen("tcp", fmt.Sprintf(":%d", global.ServerSetting.Port))
if err != nil {
log.Fatalf("[FATAL] Listen failed: %v", err)
server := grpc.NewServer(
// 创建 cmux 多路复用器
m := cmux.New(lis)
// 匹配 gRPC 连接
grpcLis := m.MatchWithWriters(cmux.HTTP2MatchHeaderFieldSendSettings("content-type", "application/grpc"))
// 匹配 HTTP 连接
httpLis := m.Match(cmux.HTTP1Fast())
// 初始化 gRPC 服务器
grpcServer := grpc.NewServer(
grpc.StreamInterceptor(grpc_middleware.ChainStreamServer(
middleware.StreamGSError500(),
......@@ -128,36 +139,43 @@ func main() {
middleware.UnaryGSError500(),
proto.RegisterTencentNluServer(server, &service.TencentNlu{})
proto.RegisterTencentNluServer(grpcServer, &service.TencentNlu{})
_ = consul.RegisterService(global.ServerSetting) //将服务注册到注册中心
grpc_health_v1.RegisterHealthServer(server, &consul.HealthImpl{}) //执行健康检查
reflection.Register(server)
// 启动 gRPC 服务
go func() {
global.Logger.Info("service is running......")
if err := server.Serve(lis); err != nil {
log.Fatalf("[FATAL] gRPC serve error: %v", err)
grpc_health_v1.RegisterHealthServer(grpcServer, &consul.HealthImpl{})
reflection.Register(grpcServer)
// 初始化并启动 HTTP 服务
// 初始化 HTTP 服务器
gin.SetMode(global.ServerSetting.RunMode)
engine := router.InitRouter()
_ = engine.SetTrustedProxies(nil) //不使用信任代理功能,即不使用gin策略再对来源过滤
s := http.Server{
Addr: ":" + global.ServerSetting.HttpPort,
httpServer := &http.Server{
Handler: engine,
//ReadTimeout: global.ServerSetting.ReadTimeout, //设置连接的最大读取时间
//WriteTimeout: global.ServerSetting.WriteTimeout, //设置连接的最大写入时间
ReadTimeout: 10 * time.Second,
WriteTimeout: 10 * time.Second,
MaxHeaderBytes: 1 << 20,
// 启动 cmux 多路复用器
go func() {
if err := m.Serve(); err != nil {
log.Fatalf("[FATAL] cmux serve error: %v", err)
// 启动 gRPC 服务
go func() {
global.Logger.Info("gRPC service is running...")
if err := grpcServer.Serve(grpcLis); err != nil {
// 启动 HTTP 服务
go func() {
global.Logger.Infof("HTTP service is running on port %s", "global.ServerSetting.HttpPort")
if err := s.ListenAndServe(); err != nil && err != http.ErrServerClosed {
global.Logger.Infof("HTTP service is running on port %d", global.ServerSetting.Port)
if err := httpServer.Serve(httpLis); err != nil && err != http.ErrServerClosed {
log.Fatalf("[FATAL] HTTP serve error: %v", err)
......@@ -175,11 +193,11 @@ func main() {
defer cancel()
// 先关闭HTTP服务
if err := s.Shutdown(ctx); err != nil {
if err := httpServer.Shutdown(ctx); err != nil {
log.Printf("[WARN] HTTP server shutdown error: %v", err)
server.GracefulStop()
grpcServer.GracefulStop()
log.Println("[INFO] Server stopped")
......@@ -18,11 +18,7 @@ type ConsulSettingS struct {
ConsulToken string
Interval time.Duration
Deregister time.Duration
HttpPort string
UriPath string
ReadTimeout time.Duration
WriteTimeout time.Duration
//DefaultContextTimeout time.Duration
func RegisterService(cs *ConsulSettingS) error {
