Skip to content
GitLab
Projects
Groups
Snippets
Help
Loading...
Help
Help
Support
Community forum
Keyboard shortcuts
Submit feedback
Contribute to GitLab
Sign in
Toggle navigation
E
elp
Project overview
Project overview
Details
Activity
Releases
Repository
Repository
Files
Commits
Branches
Tags
Contributors
Graph
Compare
Issues
0
Issues
0
List
Boards
Labels
Service Desk
Milestones
Merge Requests
0
Merge Requests
0
CI / CD
CI / CD
Pipelines
Jobs
Schedules
Operations
Operations
Incidents
Environments
Packages & Registries
Package Registry
Analytics
Analytics
CI / CD
Repository
Value Stream
Wiki
Wiki
Snippets
Snippets
Members
Members
Collapse sidebar
Close sidebar
Activity
Graph
Create a new issue
Jobs
Commits
Issue Boards
Open sidebar
崔为之
elp
Commits
1c58b6e6
Commit
1c58b6e6
authored
Nov 03, 2023
by
崔为之
Browse files
Options
Browse Files
Download
Email Patches
Plain Diff
parent
08aaa17a
Changes
5
Hide whitespace changes
Inline
Side-by-side
Showing
5 changed files
with
70 additions
and
17 deletions
+70
-17
application/config/config.yaml
+4
-2
application/extensions/init_sqlalchemy.py
+14
-2
application/utils/__init__.py
+1
-1
application/utils/dsn/__init__.py
+1
-1
application/utils/dsn/dsn.py
+50
-11
No files found.
View file @
1c58b6e6
System
System
Env
public
Env
public
MySQL
Database
User
root
Type
mysql
Driver
pymysql
Username
root
Password
localhost123
Password
localhost123
Host
localhost
Host
localhost
Port
3306
Port
3306
View file @
1c58b6e6
@@ -13,7 +13,7 @@
@@ -13,7 +13,7 @@
from
flask
import
Flask
from
flask
import
Flask
from
flask_sqlalchemy
import
SQLAlchemy
from
flask_sqlalchemy
import
SQLAlchemy
from
application.utils
import
dsn
from
application.utils
import
DatabaseURI
db
SQLAlchemy
db
SQLAlchemy
@@ -25,5 +25,17 @@ def init_database(app: Flask) -> None:
:param app: flask.Flask application instance
:return: None
:return: None
app
config
setdefault
'SQLALCHEMY_DATABASE_URI'
dsn
app
cfg
app
config
get
'Database'
if
cfg
is
None
raise
KeyError
'Key Database error'
uri
DatabaseURI
db_type
cfg
Type
username
cfg
Username
password
cfg
Password
host
cfg
Host
port
cfg
Port
db
cfg
DB
driver
cfg
Driver
app
config
setdefault
uri
create
db
init_app
app
db
init_app
app
View file @
1c58b6e6
@@ -10,5 +10,5 @@
@@ -10,5 +10,5 @@
# @Description :
# @Description :
from
.dsn
import
dsn
from
.dsn
import
dsn
DatabaseURI
from
.elasticsearch
import
ElasticsearchUtils
from
.elasticsearch
import
ElasticsearchUtils
View file @
1c58b6e6
@@ -10,4 +10,4 @@
@@ -10,4 +10,4 @@
# @Description :
# @Description :
from
.dsn
import
dsn
from
.dsn
import
DatabaseURI
View file @
1c58b6e6
@@ -10,18 +10,57 @@
@@ -10,18 +10,57 @@
# @Description :
# @Description :
from
flask
import
Flask
class
DatabaseURI
def
dsn
app
Flask
str
Initialize the MySQL dsn extension
The DatabaseURI class is a utility for generating SQLAlchemy database
connection strings for various types of databases.
:param db_type: The type of the database. It could be "mysql", "postgresql", "oracle", "sqlite".
:return: dsn
:param username: The username of the database. Not required for "sqlite".
:param password: The password of the database. Not required for "sqlite".
:param host: The host of the database. Not required for "sqlite".
:param port: The port of the database. Not required for "sqlite".
:param db: The database name. For "sqlite", it is the path to the database file.
:param driver: The python library to connect to the database. Not required but could be provided.
mysql_cfg
app
config
get
'MySQL'
if
mysql_cfg
is
None
def
__init__
self
raise
KeyError
'Key MySQL error'
db_type
str
f
'mysql+pymysql://
app
config
MySQL
User
username
str
None
f
app
config
MySQL
Password
app
config
MySQL
Host
app
config
MySQL
Port
app
config
MySQL
DB
password
str
None
host
str
None
port
str
None
db
str
None
driver
str
None
None
self
db_type
db_type
self
username
username
self
password
password
self
host
host
self
port
port
self
db
db
self
driver
driver
def
create
self
str
Creates a SQLAlchemy engine string for the specified database.
:return: A SQLAlchemy engine string.
# SQLite database only require a path to the database file
if
self
db_type
'sqlite'
f
self
db_type
self
db
else
# Other databases require a full connection string with optional driver
if
self
driver
f
self
db_type
self
driver
f
self
username
self
password
self
host
self
port
self
db
else
f
self
db_type
self
username
self
password
self
host
self
port
self
db
def
__repr__
self
f
"<DatabaseURI(
self
db_type
def
__str__
self
self
create
Write
Preview
Markdown
is supported
0%
Try again
or
attach a new file
Attach a file
Cancel
You are about to add
0
people
to the discussion. Proceed with caution.
Cancel
Please
register
or
sign in
to comment
