Skip to content
GitLab
Projects
Groups
Snippets
Help
Loading...
Help
Help
Support
Community forum
Keyboard shortcuts
Submit feedback
Contribute to GitLab
Sign in
Toggle navigation
E
elp
Project overview
Project overview
Details
Activity
Releases
Repository
Repository
Files
Commits
Branches
Tags
Contributors
Graph
Compare
Issues
0
Issues
0
List
Boards
Labels
Service Desk
Milestones
Merge Requests
0
Merge Requests
0
CI / CD
CI / CD
Pipelines
Jobs
Schedules
Operations
Operations
Incidents
Environments
Packages & Registries
Package Registry
Analytics
Analytics
CI / CD
Repository
Value Stream
Wiki
Wiki
Snippets
Snippets
Members
Members
Collapse sidebar
Close sidebar
Activity
Graph
Create a new issue
Jobs
Commits
Issue Boards
Open sidebar
崔为之
elp
Commits
50a7f9c4
Commit
50a7f9c4
authored
Nov 21, 2023
by
崔为之
Browse files
Options
Browse Files
Download
Email Patches
Plain Diff
parent
07a805f8
Changes
Hide whitespace changes
Inline
Side-by-side
Showing
1 changed file
with
14 additions
and
19 deletions
+14
-19
application/utils/dsn/redis.py
+14
-19
No files found.
View file @
50a7f9c4
@@ -7,7 +7,7 @@
@@ -7,7 +7,7 @@
# @Email : StudentCWZ@outlook.com
# @Date : 2023/11/7 15:47
# @File : redis.py
# @File : redis.py
# @Description :
# @Description :
Defines the RedisUri class for generating a Redis connection URI.
@@ -15,21 +15,16 @@ class RedisUri:
A class to generate a Redis connection URI.
def
__init__
self
host
'localhost'
port
6379
db
0
username
None
password
None
def
__init__
self
host
'localhost'
port
6379
db
0
username
None
password
None
Initializes a new instance of the RedisUri class.
:param host: The hostname of the Redis server. Default is 'localhost'.
Args:
:type host: str
host (str): The hostname of the Redis server. Default is 'localhost'.
:param port: The port number to connect to the Redis server. Default is 6379.
port (int): The port number to connect on the Redis server. Default is 6379.
:type port: int
db (int): The database number to connect on the Redis server. Default is 0.
:param db: The database number to connect to on the Redis server. Default is 0.
username (str, optional): The username for authentication to the Redis server.
:type db: int
password (str, optional): The password for authentication to the Redis server.
:param username: The username for authentication to the Redis server. Default is None.
:type username: str
:param password: The password for authentication to the Redis server. Default is None.
:type password: str
self
host
host
self
host
host
self
port
port
self
port
port
@@ -41,8 +36,8 @@ class RedisUri:
Creates and returns the Redis connection URI.
:return: The Redis connection URI.
Returns:
:rtype: str
str: The Redis connection URI.
if
self
username
and
self
password
if
self
username
and
self
password
f
'redis://
self
username
self
password
self
host
self
port
self
db
f
'redis://
self
username
self
password
self
host
self
port
self
db
@@ -53,17 +48,17 @@ class RedisUri:
Returns a formal string representation of the RedisUri object.
:return: The formal string representation of the RedisUri object.
Returns:
:rtype: str
str: The formal string representation of the RedisUri object.
f
'RedisUri(host=
self
host
, port=
self
port
, db=
self
db
, username=
self
username
f
'RedisUri(host=
self
host
, port=
self
port
, db=
self
db
, username=
self
username
f
'password=
self
password
f
'password=
self
password
def
__str__
self
def
__str__
self
Returns a string representation of the RedisUri object.
, which is the Redis connection URI
:return: The string representation of the RedisUri object.
Returns:
:rtype: str
str: The string representation of the RedisUri object.
self
create
self
create
Write
Preview
Markdown
is supported
0%
Try again
or
attach a new file
Attach a file
Cancel
You are about to add
0
people
to the discussion. Proceed with caution.
Cancel
Please
register
or
sign in
to comment
