Skip to content
GitLab
Projects
Groups
Snippets
Help
Loading...
Help
Help
Support
Community forum
Keyboard shortcuts
Submit feedback
Contribute to GitLab
Sign in
Toggle navigation
E
elp
Project overview
Project overview
Details
Activity
Releases
Repository
Repository
Files
Commits
Branches
Tags
Contributors
Graph
Compare
Issues
0
Issues
0
List
Boards
Labels
Service Desk
Milestones
Merge Requests
0
Merge Requests
0
CI / CD
CI / CD
Pipelines
Jobs
Schedules
Operations
Operations
Incidents
Environments
Packages & Registries
Package Registry
Analytics
Analytics
CI / CD
Repository
Value Stream
Wiki
Wiki
Snippets
Snippets
Members
Members
Collapse sidebar
Close sidebar
Activity
Graph
Create a new issue
Jobs
Commits
Issue Boards
Open sidebar
崔为之
elp
Commits
5a67515b
Commit
5a67515b
authored
Nov 04, 2023
by
崔为之
Browse files
Options
Browse Files
Download
Email Patches
Plain Diff
parent
bb11b14a
Changes
3
Hide whitespace changes
Inline
Side-by-side
Showing
3 changed files
with
76 additions
and
16 deletions
+76
-16
application/common/__init__.py
+1
-0
application/common/env.py
+44
-0
application/utils/loaders/consul_loader.py
+31
-16
No files found.
View file @
5a67515b
@@ -11,4 +11,5 @@
@@ -11,4 +11,5 @@
from
.config
import
ConfigHelper
from
.config
import
ConfigHelper
from
.env
import
EnvVarHelper
from
.file
import
FileHelper
from
.file
import
FileHelper
0 → 100644
View file @
5a67515b
#!/usr/bin/env python3
# -*- coding: utf-8 -*-
# @Version : Python 3.11.4
# @Software : Sublime Text 4
# @Author : StudentCWZ
# @Email : StudentCWZ@outlook.com
# @Date : 2023/11/4 11:15
# @File : env.py
# @Description :
import
os
from
typing
import
Union
class
EnvVarHelper
A helper class for handling environment variables.
property
def
consul_vars
self
dict
Get the consul-related environment variables.
:return: a dict containing the consul-related environment variables.
'host'
os
environ
get
'CONSUL_HOST'
'localhost'
'port'
os
environ
get
'CONSUL_PORT'
8500
'dc'
os
environ
get
'CONSUL_DC'
'dc1'
'token'
os
getenv
'CONSUL_TOKEN'
None
'key'
os
getenv
'CONSUL_KEY'
None
def
__getattr__
self
name
str
Union
dict
None
Get an environment variable as an attribute.
:param name: The name of the environment variable.
:return: The value of the environment variable, or None if it does not exist.
os
environ
get
name
View file @
5a67515b
@@ -10,28 +10,27 @@
@@ -10,28 +10,27 @@
# @Description :
# @Description :
import
os
from
typing
import
Union
from
typing
import
NamedTuple
Union
import
requests
import
requests
from
dynaconf.base
import
LazySettings
from
dynaconf.base
import
LazySettings
from
dynaconf.utils.parse_conf
import
parse_conf_data
from
import
parse_conf_data
from
application.common
import
EnvVarHelper
from
application.lib
import
ConsulConfig
from
application.lib
import
ConsulConfig
IDENTIFIER
"consul_loader"
IDENTIFIER
"consul_loader"
def
get_env_vars
dict
'host'
os
environ
get
'CONSUL_HOST'
'localhost'
'port'
os
environ
get
'CONSUL_PORT'
8500
'dc'
os
environ
get
'CONSUL_DC'
'dc1'
'token'
os
getenv
'CONSUL_TOKEN'
def
parse_config
data
dict
key
str
obj
LazySettings
dict
def
parse_config
data
dict
key
str
obj
LazySettings
dict
Parses the configuration data.
:param data: The configuration data.
:param key: The key to be parsed in the configuration.
:param obj: The LazySettings object.
:return: A dictionary with parsed configuration data.
if
key
is
not
None
if
key
is
not
None
data
data
key
data
data
key
@@ -48,10 +47,25 @@ def load(
key
str
None
key
str
None
validate
False
validate
False
Union
bool
None
Union
bool
None
env_vars
get_env_vars
consul_key
os
getenv
'CONSUL_KEY'
Loads the configuration data.
if
consul_key
is
None
:param env: The environment.
:param silent: If True, suppress exceptions.
:param key: The key to be loaded in the configuration.
:param validate: If True, validate the configuration.
:return: Boolean indicating success, or None in case of failure.
# 实例化对象
env_helper
EnvVarHelper
# 从环境变量获取 consul 参数
env_vars
env_helper
consul_vars
# 获取 consul key
consul_key
env_vars
pop
'key'
None
# If the key is None or empty, return None
if
not
consul_key
client
ConsulConfig
env_vars
client
ConsulConfig
env_vars
@@ -61,7 +75,8 @@ def load(
except
requests
exceptions
ConnectionError
except
requests
exceptions
ConnectionError
except
Exception
as
e
except
Exception
as
e
raise
RuntimeError
f
'Unknown error:
e
# Include original exception in the traceback
raise
RuntimeError
f
'Unknown error:
e
from
e
if
env
is
None
if
env
is
None
Write
Preview
Markdown
is supported
0%
Try again
or
attach a new file
Attach a file
Cancel
You are about to add
0
people
to the discussion. Proceed with caution.
Cancel
Please
register
or
sign in
to comment
