Commit 5a67515b authored by 崔为之's avatar 崔为之 💪🏽
parent bb11b14a
...@@ -11,4 +11,5 @@ ...@@ -11,4 +11,5 @@
from .config import ConfigHelper from .config import ConfigHelper
from .env import EnvVarHelper
from .file import FileHelper from .file import FileHelper
#!/usr/bin/env python3
# -*- coding: utf-8 -*-
# @Version : Python 3.11.4
# @Software : Sublime Text 4
# @Author : StudentCWZ
# @Email : StudentCWZ@outlook.com
# @Date : 2023/11/4 11:15
# @File : env.py
# @Description :
import os
from typing import Union
class EnvVarHelper:
A helper class for handling environment variables.
@property
def consul_vars(self) -> dict:
Get the consul-related environment variables.
:return: a dict containing the consul-related environment variables.
return {
'host': os.environ.get('CONSUL_HOST', 'localhost'),
'port': os.environ.get('CONSUL_PORT', 8500),
'dc': os.environ.get('CONSUL_DC', 'dc1'),
'token': os.getenv('CONSUL_TOKEN', None),
'key': os.getenv('CONSUL_KEY', None),
def __getattr__(self, name: str) -> Union[dict, None]:
Get an environment variable as an attribute.
:param name: The name of the environment variable.
:return: The value of the environment variable, or None if it does not exist.
return os.environ.get(name)
...@@ -10,28 +10,27 @@ ...@@ -10,28 +10,27 @@
# @Description : # @Description :
import os from typing import Union
from typing import NamedTuple, Union
import requests import requests
from dynaconf.base import LazySettings from dynaconf.base import LazySettings
from dynaconf.utils.parse_conf import parse_conf_data from dynaconf.utils.parse_conf import parse_conf_data
from application.common import EnvVarHelper
from application.lib import ConsulConfig from application.lib import ConsulConfig
IDENTIFIER = "consul_loader" IDENTIFIER = "consul_loader"
def get_env_vars() -> dict:
return {
'token': os.getenv('CONSUL_TOKEN'),
def parse_config(data: dict, key: str, obj: LazySettings) -> dict: def parse_config(data: dict, key: str, obj: LazySettings) -> dict:
Parses the configuration data.
:param data: The configuration data.
:param key: The key to be parsed in the configuration.
:param obj: The LazySettings object.
:return: A dictionary with parsed configuration data.
if key is not None: if key is not None:
data = data[key] data = data[key]
...@@ -48,10 +47,25 @@ def load( ...@@ -48,10 +47,25 @@ def load(
key: str = None, key: str = None,
validate=False, validate=False,
) -> Union[bool, None]: ) -> Union[bool, None]:
env_vars = get_env_vars() """
consul_key = os.getenv('CONSUL_KEY') Loads the configuration data.
if consul_key is None: :param obj: The LazySettings object.
:param env: The environment.
:param silent: If True, suppress exceptions.
:param key: The key to be loaded in the configuration.
:param validate: If True, validate the configuration.
:return: Boolean indicating success, or None in case of failure.
# 实例化对象
env_helper = EnvVarHelper()
# 从环境变量获取 consul 参数
env_vars = env_helper.consul_vars
# 获取 consul key
consul_key = env_vars.pop('key', None)
# If the key is None or empty, return None
if not consul_key:
return return
client = ConsulConfig(**env_vars) client = ConsulConfig(**env_vars)
...@@ -61,7 +75,8 @@ def load( ...@@ -61,7 +75,8 @@ def load(
except requests.exceptions.ConnectionError: except requests.exceptions.ConnectionError:
return return
except Exception as e: except Exception as e:
raise RuntimeError(f'Unknown error: {e}') # Include original exception in the traceback
raise RuntimeError(f'Unknown error: {e}') from e
if env is None: if env is None:
return return
