Commit 9416fd84 authored by 崔为之's avatar 崔为之 💪🏽
parent a148dedb
...@@ -11,4 +11,4 @@ ...@@ -11,4 +11,4 @@
from .dsn import DatabaseURI from .dsn import DatabaseURI
from .elasticsearch import ElasticsearchUtils from .elasticsearch import ElasticsearchUtil
...@@ -10,4 +10,4 @@ ...@@ -10,4 +10,4 @@
# @Description : # @Description :
...@@ -15,7 +15,7 @@ import datetime ...@@ -15,7 +15,7 @@ import datetime
from application.extensions.init_elasticsearch import es from application.extensions.init_elasticsearch import es
class ElasticsearchUtils: class ElasticsearchUtil:
@classmethod @classmethod
def dsl(cls, _start: str, _end: str, size=10000) -> dict: def dsl(cls, _start: str, _end: str, size=10000) -> dict:
...@@ -16,7 +16,7 @@ from application.services import UserService ...@@ -16,7 +16,7 @@ from application.services import UserService
from marshmallow import ValidationError from marshmallow import ValidationError
from application.schemas import UserSchema from application.schemas import UserSchema
from application.utils import ElasticsearchUtils from application.utils import ElasticsearchUtil
from application.common import ConfigHelper from application.common import ConfigHelper
user_api = Blueprint('user_api', __name__) user_api = Blueprint('user_api', __name__)
...@@ -58,9 +58,9 @@ def test_user(): ...@@ -58,9 +58,9 @@ def test_user():
data = request.get_json() data = request.get_json()
start = data.get('start') start = data.get('start')
end = data.get('end') end = data.get('end')
dsl = ElasticsearchUtils.dsl(start, end) dsl = ElasticsearchUtil.dsl(start, end)
index = current_app.config.Elasticsearch.Index index = current_app.config.Elasticsearch.Index
res = ElasticsearchUtils.search(index, dsl) res = ElasticsearchUtil.search(index, dsl)
print(len(res)) print(len(res))
data = { data = {
"user_name": "libai", "user_name": "libai",
