Skip to content
GitLab
Projects
Groups
Snippets
Help
Loading...
Help
Help
Support
Community forum
Keyboard shortcuts
Submit feedback
Contribute to GitLab
Sign in
Toggle navigation
E
elp
Project overview
Project overview
Details
Activity
Releases
Repository
Repository
Files
Commits
Branches
Tags
Contributors
Graph
Compare
Issues
0
Issues
0
List
Boards
Labels
Service Desk
Milestones
Merge Requests
0
Merge Requests
0
CI / CD
CI / CD
Pipelines
Jobs
Schedules
Operations
Operations
Incidents
Environments
Packages & Registries
Package Registry
Analytics
Analytics
CI / CD
Repository
Value Stream
Wiki
Wiki
Snippets
Snippets
Members
Members
Collapse sidebar
Close sidebar
Activity
Graph
Create a new issue
Jobs
Commits
Issue Boards
Open sidebar
崔为之
elp
Commits
ca65d190
Commit
ca65d190
authored
Nov 20, 2023
by
崔为之
Browse files
Options
Browse Files
Download
Email Patches
Plain Diff
parent
21734a2e
Changes
17
Hide whitespace changes
Inline
Side-by-side
Showing
17 changed files
with
7 additions
and
310 deletions
+7
-310
application/config/config.yaml
+1
-1
application/dao/__init__.py
+0
-1
application/dao/log.py
+1
-2
application/dao/user.py
+0
-31
application/extensions/init_sqlalchemy.py
+0
-11
application/libs/tasks/task.py
+0
-7
application/models/__init__.py
+0
-1
application/models/log.py
+0
-13
application/models/user.py
+0
-66
application/schemas/__init__.py
+0
-2
application/schemas/user.py
+0
-49
application/script/cmdline.py
+5
-7
application/services/__init__.py
+0
-1
application/services/user.py
+0
-28
application/views/__init__.py
+0
-2
application/views/user/__init__.py
+0
-19
application/views/user/user.py
+0
-69
No files found.
View file @
ca65d190
@@ -9,7 +9,7 @@ Database:
Host
localhost
Host
localhost
Port
5432
Port
5432
DB
elp
DB
elp
TableName
user
s
TableName
log
s
Elasticsearch
Elasticsearch
Host
172.28.5.39
Host
172.28.5.39
View file @
ca65d190
@@ -10,5 +10,4 @@
@@ -10,5 +10,4 @@
# @Description :
# @Description :
from
.user
import
UserDao
from
.log
import
LogDao
from
.log
import
LogDao
View file @
ca65d190
@@ -13,10 +13,9 @@
@@ -13,10 +13,9 @@
from
loguru
import
logger
from
loguru
import
logger
from
application.utils
import
ElasticsearchUtil
from
application.libs.helper
import
MySQLHelper
from
import
MySQLHelper
from
application.utils
import
ParseUtil
from
application.models
import
Log
from
application.models
import
Log
from
application.utils
import
ElasticsearchUtil
ParseUtil
class
LogDao
class
LogDao
deleted
100644 → 0
View file @
21734a2e
#!/usr/bin/env python3
# -*- coding: utf-8 -*-
# @Version : Python 3.11.4
# @Software : Sublime Text 4
# @Author : StudentCWZ
# @Email : StudentCWZ@outlook.com
# @Date : 2023/10/28 23:56
# @File : user.py
# @Description :
from
application.extensions.init_sqlalchemy
import
db
from
application.models.user
import
User
class
UserDao
classmethod
def
get_all
cls
User
query
all
classmethod
def
get_by_id
cls
user_id
int
User
query
get
user_id
classmethod
def
create
cls
username
str
password
str
email
str
new_user
User
username
username
email
email
password
password
db
session
add
new_user
db
session
commit
new_user
View file @
ca65d190
@@ -42,17 +42,6 @@ def init_database(app: Flask) -> None:
with
app
app_context
with
app
app_context
db
session
execute
text
f
db
session
execute
text
f
CREATE TABLE IF NOT EXISTS
cfg
TableName
cfg
TableName
id SERIAL NOT NULL,
username VARCHAR(80) NOT NULL,
email VARCHAR(120) NOT NULL,
password VARCHAR(255) NOT NULL,
active BOOLEAN,
created_at TIMESTAMP WITH TIME ZONE NOT NULL,
PRIMARY KEY (id, created_at)
) PARTITION BY RANGE (created_at);
db
session
execute
text
CREATE TABLE IF NOT EXISTS logs (
id SERIAL NOT NULL,
id SERIAL NOT NULL,
date_time TIMESTAMP WITH TIME ZONE NOT NULL,
uuid varchar(100) DEFAULT NULL,
View file @
ca65d190
@@ -12,7 +12,6 @@
@@ -12,7 +12,6 @@
import
datetime
import
datetime
from
import
db
from
import
db
from
application.models
import
User
from
import
MySQLHelper
from
import
MySQLHelper
@@ -33,9 +32,3 @@ def task():
with
MySQLHelper
options
as
helper
with
MySQLHelper
options
as
helper
print
helper
execute
cfg
Sql
print
helper
execute
cfg
Sql
print
"create user"
# user = User(username="CWzz", email="Stuu@outlook.com", password="qwe!2345", active=True,
# created_at=datetime.datetime.utcnow())
# user.save()
print
"created user admin"
View file @
ca65d190
@@ -10,5 +10,4 @@
@@ -10,5 +10,4 @@
# @Description :
# @Description :
from
.user
import
User
from
.log
import
Log
from
.log
import
Log
View file @
ca65d190
@@ -69,19 +69,6 @@ class Log(db.Model):
_dic
key
value
_dic
key
value
_dic
_dic
def
save
self
partition_date
self
date_time
strftime
'%Y_%m'
partition_name
f
self
__tablename__
_
partition_date
with
db
session
begin_nested
db
session
execute
text
f
partition_name
PARTITION OF
self
__tablename__
FOR VALUES FROM ('
self
date_time
strftime
'%Y-%m-01'
') TO
self
date_time
strftime
'%Y-%m-01'
'::date + interval '1 month');
db
session
add
self
db
session
commit
classmethod
classmethod
def
batch_save
cls
objects
def
batch_save
cls
objects
with
db
session
begin_nested
with
db
session
begin_nested
deleted
100644 → 0
View file @
21734a2e
# @Date : 2023/10/28 22:12
# @File : user.py
# @Description :
import
os
from
sqlalchemy
import
text
from
sqlalchemy.ext.hybrid
import
hybrid_property
from
application.extensions.init_bcrypt
import
bcrypt
from
import
db
class
User
db
Model
"""Basic user model"""
__tablename__
os
environ
get
'TableName'
'users'
id
db
Column
db
Integer
primary_key
True
username
db
Column
db
String
80
unique
True
nullable
False
email
db
Column
db
String
80
unique
True
nullable
False
_password
db
Column
"password"
db
String
255
nullable
False
active
db
Column
db
Boolean
default
True
created_at
db
Column
db
DateTime
nullable
False
hybrid_property
def
password
self
self
_password
password
setter
def
password
self
password
str
self
_password
bcrypt
generate_password_hash
password
decode
'utf-8'
def
check_password
self
password
str
# 判断传过来的密码是否与数据库存的密码一致
bcrypt
check_password_hash
self
_password
password
def
to_dict
self
dict
"""object to dict"""
'id'
self
id
'username'
self
username
'email'
self
email
def
__repr__
self
str
f
'<User
self
username
def
save
self
partition_date
self
created_at
strftime
'%Y_%m'
partition_name
f
self
__tablename__
_
partition_date
with
db
session
begin_nested
db
session
execute
text
f
partition_name
PARTITION OF
self
__tablename__
FOR VALUES FROM ('
self
created_at
strftime
'%Y-%m-01'
') TO
self
created_at
strftime
'%Y-%m-01'
db
session
add
self
db
session
commit
View file @
ca65d190
@@ -10,6 +10,4 @@
@@ -10,6 +10,4 @@
# @Description :
# @Description :
from
.user
import
CreateUserItem
from
.user
import
UserSchema
from
.request
import
ParseLogRequestItem
from
.request
import
ParseLogRequestItem
deleted
100644 → 0
View file @
21734a2e
# @Date : 2023/10/29 00:07
# @File : user.py
# @Description :
from
pydantic
import
BaseModel
EmailStr
field_validator
from
application.extensions.init_marshmallow
import
ma
from
import
db
from
application.models
import
User
from
marshmallow
import
validates
ValidationError
class
CreateUserItem
BaseModel
username
str
password
str
email
EmailStr
classmethod
field_validator
"username"
def
name_must_contain_only_characters
cls
value
if
not
value
isalpha
raise
ValueError
"Username must contain only characters."
value
class
UserSchema
ma
SQLAlchemyAutoSchema
id
ma
Int
dump_only
True
username
ma
Str
required
True
password
ma
String
load_only
True
required
True
email
ma
Email
required
True
class
Meta
model
User
sqla_session
db
session
load_instance
True
exclude
"_password"
validates
'username'
def
validate_username
self
username
if
len
username
3
raise
ValidationError
'Username must be at least 3 characters.'
\ No newline at end of file
View file @
ca65d190
@@ -17,12 +17,10 @@ from flask.cli import with_appcontext
click
command
"init"
click
command
"init"
with_appcontext
with_appcontext
def
init
def
init
"""Create a new
admin user
"""Create a new
log
from
import
db
from
import
db
from
application.models
import
User
click
echo
"create user"
# click.echo("create log")
user
User
username
"StudentCWZ"
email
"StudentCWZ@outlook.com"
password
"qwe!2345"
active
True
# db.session.add(user)
db
session
add
user
# db.session.commit()
db
session
commit
# click.echo("created log")
click
echo
View file @
ca65d190
@@ -10,5 +10,4 @@
@@ -10,5 +10,4 @@
# @Description :
# @Description :
from
.user
import
UserService
from
.log
import
LogService
from
.log
import
LogService
deleted
100644 → 0
View file @
21734a2e
# @Date : 2023/10/29 00:03
# @File : user.py
# @Description :
from
application.dao
import
UserDao
class
UserService
classmethod
def
get_all_users
cls
UserDao
get_all
classmethod
def
get_user_by_id
cls
user_id
int
UserDao
get_by_id
user_id
classmethod
def
create_user
cls
username
str
password
str
email
str
UserDao
create
username
password
email
View file @
ca65d190
@@ -12,10 +12,8 @@
@@ -12,10 +12,8 @@
from
flask
import
Flask
from
flask
import
Flask
from
.user
import
register_user_views
from
.log
import
register_log_views
from
.log
import
register_log_views
def
init_views
app
Flask
None
def
init_views
app
Flask
None
register_user_views
app
register_log_views
app
register_log_views
app
deleted
100644 → 0
View file @
21734a2e
# @Date : 2023/10/29 00:18
# @File : __init__.py.py
# @Description :
from
flask
import
Flask
from
.user
import
user_api
def
register_user_views
app
Flask
app
register_blueprint
user_api
deleted
100644 → 0
View file @
21734a2e
# @Date : 2023/10/29 00:08
# @File : user.py
# @Description :
import
json
from
flask
import
Blueprint
current_app
request
jsonify
from
flask_restful
import
Api
from
application.services
import
UserService
from
marshmallow
import
ValidationError
from
application.schemas
import
UserSchema
from
application.utils
import
ElasticsearchUtil
from
import
ConfigHelper
user_api
Blueprint
'user_api'
__name__
api_users
Api
user_api
user_api
route
'/users'
methods
'GET'
def
get_users
users
UserService
get_all_users
jsonify
user
to_dict
for
user
in
users
user_api
route
'/users/<int:user_id>'
methods
'GET'
def
get_user
user_id
user
UserService
get_user_by_id
user_id
if
user
is
None
jsonify
'error'
'User not found'
404
jsonify
user
to_dict
user_api
route
'/users'
methods
'POST'
def
create_user
user_schema
UserSchema
try
data
user_schema
load
request
json
except
ValidationError
as
e
jsonify
e
messages
400
username
data
username
password
data
password
email
data
email
user
UserService
create_user
username
password
email
jsonify
user_schema
dump
user
201
user_api
route
'/tests'
methods
'POST'
def
test_user
# data = request.get_json()
# start = data.get('start')
# end = data.get('end')
# dsl = ElasticsearchUtil.dsl(start, end)
# index = current_app.config.Elasticsearch.Index
# res = ElasticsearchUtil.search(index, dsl)
# print(len(res))
res
"user_name"
"libai"
"user_age"
18
res_json
json
dumps
res
res_json
200
Write
Preview
Markdown
is supported
0%
Try again
or
attach a new file
Attach a file
Cancel
You are about to add
0
people
to the discussion. Proceed with caution.
Cancel
Please
register
or
sign in
to comment
