Commit 5ca41ec9 authored by 赵文静's avatar 赵文静
修改问题
parent 293deb54
# 更新日志 # 更新日志
## [0.0.1-beta.2] - 2025.5.29
### Changed
- 补充诗词解析兜底
- 暂停闹钟直接返回解析给整机处理
## [0.0.1-beta] - 2025.5.13 ## [0.0.1-beta] - 2025.5.13
### Changed ### Changed
- 对接思必驰 - 对接思必驰
...@@ -14,7 +14,7 @@ Content-Type: application/json ...@@ -14,7 +14,7 @@ Content-Type: application/json
"trafficParameter": "mode=childxxx;macWifi=28b77c218ed1;mid=10f05;vender=7e000025;macVoice=testyuntiancloud;ver=3.0;scenario=smarthome;filterName=nlu;req_nlu_length=1;returnType=json;fullDuplex=true;appendLength=1;additionalService=geli_nlu2;version=0.5;filterUrl=https://testnlu.gree.com:443/semantic/unisoundc2c/querys;" "trafficParameter": "mode=childxxx;macWifi=28b77c218ed1;mid=10f05;vender=7e000025;macVoice=testyuntiancloud;ver=3.0;scenario=smarthome;filterName=nlu;req_nlu_length=1;returnType=json;fullDuplex=true;appendLength=1;additionalService=geli_nlu2;version=0.5;filterUrl=https://testnlu.gree.com:443/semantic/unisoundc2c/querys;"
"nluRet": { "nluRet": {
"text": "关闭闹钟" "text": "暂停闹钟"
"postProc": {} "postProc": {}
...@@ -33,7 +33,7 @@ Content-Type: application/json ...@@ -33,7 +33,7 @@ Content-Type: application/json
"asr_recongize": "", "asr_recongize": "",
"text": "关闭提醒" "text": "城春草木深下一句"
"version": "v0" "version": "v0"
...@@ -55,7 +55,7 @@ Content-Type: application/json ...@@ -55,7 +55,7 @@ Content-Type: application/json
"trafficParameter": "mode=childxx;macWifi=ece154a73d38;mid=11011;macVoice=testyuntiancloud;ver=3.0;scenario=smarthome;filterName=nlu;req_nlu_length=1;returnType=json;fullDuplex=true;appendLength=1;additionalService=geli_nlu2;version=0.5;filterUrl=https://testnlu.gree.com:443/semantic/unisoundc2c/querys;" "trafficParameter": "mode=childxx;macWifi=ece154a73d38;mid=11011;macVoice=testyuntiancloud;ver=3.0;scenario=smarthome;filterName=nlu;req_nlu_length=1;returnType=json;fullDuplex=true;appendLength=1;additionalService=geli_nlu2;version=0.5;filterUrl=https://testnlu.gree.com:443/semantic/unisoundc2c/querys;"
"text": "停止提醒" "text": "后天天气"
...@@ -247,13 +247,16 @@ func ancientpoemDomain(params *model.SpeechDomainParams) []byte { ...@@ -247,13 +247,16 @@ func ancientpoemDomain(params *model.SpeechDomainParams) []byte {
if params.SpeechWsResp.Dm.IntentName == "查询诗词释义" { if params.SpeechWsResp.Dm.IntentName == "查询诗词释义" {
res.Header.Semantic.Intent = "search_ancientpoem_meaning" res.Header.Semantic.Intent = "search_ancientpoem_meaning"
res.ListItems = append(res.ListItems, map[string]interface{}{ if params.SpeechWsResp.Dm.Widget.Extra.ContentTranslation == "" { //如果返回列表,整机是播放content里的消息
"content": params.SpeechWsResp.Dm.Widget.Extra.ContentTranslation, } else {
"title": params.SpeechWsResp.Dm.Widget.Extra.Title, res.ListItems = append(res.ListItems, map[string]interface{}{
"type": "TEXT", //原来是 TEXT,看看是否能播放 "content": params.SpeechWsResp.Dm.Widget.Extra.ContentTranslation,
"url": "", "title": params.SpeechWsResp.Dm.Widget.Extra.Title,
"mediaId": "", "type": "TEXT", //原来是 TEXT,看看是否能播放
}) "url": "",
"mediaId": "",
res.Header.Semantic.SkillId = res.Header.Semantic.Domain + "." + res.Header.Semantic.Intent res.Header.Semantic.SkillId = res.Header.Semantic.Domain + "." + res.Header.Semantic.Intent
return Marshal(params, res) return Marshal(params, res)
} else if params.SpeechWsResp.Dm.IntentName == "查询诗句" { } else if params.SpeechWsResp.Dm.IntentName == "查询诗句" {
...@@ -464,6 +467,9 @@ func alarmDomain(params *model.SpeechDomainParams) []byte { ...@@ -464,6 +467,9 @@ func alarmDomain(params *model.SpeechDomainParams) []byte {
result.Header.Semantic.Intent = "delete" result.Header.Semantic.Intent = "delete"
} else if api == "ai.dui.dskdm.reminder.shut" { } else if api == "ai.dui.dskdm.reminder.shut" {
result.Header.Semantic.Intent = "stop" result.Header.Semantic.Intent = "stop"
result.Header.Semantic.SkillId = result.Header.Semantic.Domain + "." + result.Header.Semantic.Intent
result.ResponseText = "好的。"
return Marshal(params, &result)
result.Header.Semantic.SkillId = result.Header.Semantic.Domain + "." + result.Header.Semantic.Intent result.Header.Semantic.SkillId = result.Header.Semantic.Domain + "." + result.Header.Semantic.Intent
